[SOLVED] Possible overheating
nitra93
17
Hi everyone, I just need a bit of advice. I just bought a prebuilt system, this one:
https://www.overclockers.co.uk/ocuk...d-ryzen-5-amd-radeon-rx-fs-1cy-og.html#t=d4f2
I upgraded it to the Rx 5700xt. It works like a dream but I've noticed that it doesn't have any front fans or top fans, just the 1 rear fan. There was no option to configure this on the website so I assumed it was just fine. I've been running MSI after burner and my gpu gets to max 80c, CPU is around the same as I know ryzen can run hotter then most. It's just the glass on the case gets so hot and it heats up the room ridiculously. There's no other problems with it, just wondered what you guys think and whether it'll be okay. If it's an issue then is a bit dodgy selling this with heat problems.
I personally wouldn't worry about it too much. Those temperatures aren't great, but they aren't dangerous, as far as I know. If there are places in your case for more fans, I think it would be a good idea to buy some, and put them in yourself.
