Question possible problem with graphic card with Motherboard knup revenger H110
Klebermo
13
Do not create another thread on this topic. Four threads have been combined here.
After build a system with this Motherboard, a Intel ore i3-9100F CPU and a Geforce GTX 1650 CPU, when I try turn on the system, I got a longo beep and three short ones.
I was unable to find the exact meaning of the beeps for this Motherboard, but some sites in my search are saying this is a problem with the graphic card.
The graphic card was working Fine in another build (with a different Motherboard). I have tried another GPU with this Motherboard (Radeon RX 550), and the some sequence of beeps ocurred; because that I suspected the information I get about the meaning of this beeps was correct, but I was not able to find a confirmation anywhere.
Is this really the case? Anyone can give any tips of How to fix that?
Normally error codes for the GPU. Remove the graphics card and then reseat it and check its fully positioned and seated in the mobo slot. If you have an inbuilt graphics on the motherboard, go into bios and turn off.
If there is an inbuilt gpu, and it is already turned off, then turn it on and connect the video cable to the motherboard graphics to see if that works.
The CPU does not have an integrated Gpu, because. I already tried remove The Gpu, clean it The slots and conector, and instala again.
I have this Core i3-9100f CPU which was working normally on an Asus Prime Z370-A board, but right now I have a problem when I try this same CPU with these two boards:
1) Asus Prime Z370-A
2) Knup Revenger H110
With both boards I get an error that In my searches seems to be related to a video card issue:
1 long beep +3/4 short beeps.
I have tried a GTX 1650 and an RX 550 in my builds.
Could this be a CPU issue or something else?
Is there any workaround to make the system work?
Asus Prime Z370-A requires BIOS update 1412 - for i3-9100f.
If you have sufficient BIOS version and it's still not working, then you may have some bent/broken pins in cpu socket.
H110 board is not compatible with i3-9100f. It will never work on this board.
It was working with the Asus board before.
View: https://youtube.com/shorts/xICqgFWhVfw?si=UPL_00qWesp5QcYY
First I thought this could be 1 long beep and 3 short beeps, indicating an issue with the graphic card, but now I am not sure the First beeps is a longo onde.
I also thought the First beeps was not parte of the error, making the error 3 short beeps (memory issue?). I try adjust the memory, try using only 1 slot (with both positions) and different Memories, and the some error happened.
Maybe the error could be 4 short beeps? This indicate a timer issue accordind to my search, but I do not know How to troubleshoot this. And do not understand this pause between the First and Second beeps.
My system has this component:
CPU: core i3-6100
Ram: 2x hyperx 8gb
Motherboard: knup revenger h110
GPU: geforce GTX 1650
That's 3 short beeps. The first one is just the normal Beep indicating that BIOS is now running startup checks.
List ALL of the hardware at play here else no one will be able to advise further than that.
Everything I have installed is listed on the bottom of the original post
I have this components in my system:
  • Motherboard knup revenger h110
  • CPU Intel core i3-6100
  • 2x HyperX 8GB
  • GPU geforce GTX 1650 ( also tested with Radeon RX 550 and internal graphics)
  • nvMe WD Green 240GB
  • Psu XFX XTR2 850W
When I try turn on, I get one inicial beep, a pause, and 3 short beeps. What I try:
  • Change the memory sticks (I have tried 2 different pairs, install only one sticks in different slots)
  • Start with no nvMe
Anyone have another suggestions?
View: https://imgur.com/a/WLOVut8
View: https://youtube.com/shorts/xICqgFWhVfw?si=MnksAN7_pCRnDDTd
