Virtual_Singularity :
Your best bet would've been using the original packaging of your gtx 970. But since that may not have been possible for whatever reason... You can more or less rest easy, knowing the bubble wrap used will (or should) protect said gpu from any possible static electricity damage.
Not true, unless this was metalized or pink bubble wrap. Clear bubblewrap can generate static.
Unknown if you did any damage.
