Built a PC a few days ago. Worked fine save for a few issues:
I tried plugging the fan into the mobo header, pins aligned right (I believe), and set the bios to run it in 3-pin mode. Fan didn't work but I did notice a burning plastic smell near the header/gpu when I went to turn it off.
I gave up on trying to get the fan to work for the meantime and booted it up to tackle the resolution issue, which was basically just messing with overscan settings in the Nvidia control panel. I rebooted and got a black screen - no BIOS or OS.
This is where I'm at now. No image from the 970 whatsoever.
Replacing it with an older GPU shows the BIOS and allows me to boot into Windows 10. The resolution is still screwed, I don't know if this is just because it's an ancient GPU (GTS 250). Booting into Xubuntu gives a black screen but with backlighting. I tried booting into it off an installation USB and had to change USB ports and use safe graphics mode for it to work.
I've tried jumping the CMOS. The 970 is definitely placed firmly into the PCIE slot, and the 8-pin power is connected. My main concern is the GPU is dead but this doesn't seem to be the only issue. At the moment it's like half of my pc is malfunctioning - I do not feel very lucky. Would appreciate some help.
My parts are as follows:
Ryzen 5 1400
Silverstone Essential ET550-G
Gigabyte B450M S2H V2
Asus GTX 970
Samsung 860 Evo 500gb
Corsair Vengeance LPX 16gb
Thermaltake Armour+ MX
- I was having resolution issues with the monitor. If I connect it to my laptop via VGA it works fine, but if I connected it to the gpu (GTX 970) using HDMI and set it to native resolution the image would be too large for the screen, and I'd have to set it to a lower resolution just to see everything. It worked fine on a different (larger) monitor.
- An old case fan wasn't able to be powered via the motherboard header - I still don't know the root of this problem unfortunately. I have another thread on this.
- I have a dualboot system (Windows and Xubuntu) but for some reason the grub menu isn't showing up - I have to go into bios to set the boot partition manually.
Ryzen 5 1400
Asus GTX 970
