[SOLVED] Possibly low FPS/ Micro stuttering on PUBG
abhishek2696hhh
57
6
10,535
MOBO - ASUS ROG STRIX x570 GAMING-E
Ryzen 5 3900x
ASUS ROG STRIX RTX 2080 SUPER ADVANCED
8GB x 2 (16GB total) RAM G.skill Trident RGB 3200mhz
Noctua NH-D15s Air Cooler
PSU Corsair HX-750
240 GB WD GREEN SATA SSD
1 TB SEAGATE FIRECCUDA
So i just got a asus rtx 2080 super advanced and decided to play pubg on it with everything set to ultra at 1440p.
I get a lot of stuttering idk for what reason
Whenever I aim down the sights it kind of skips and isnt a smooth transition.
The FPS is usually around 90ish
Is this normal?
Every benchmark I see with the same setup shows an fps of 120+ 🙁
use ddu uninstaller to remove all previously installed GPU drivers
reinstall the nvidia.com driver
install AMD drivers for chipset
check temperatures of CPU and GPU
run 3dmark basic edition , click on compare result online after that and post the address from your upcoming browser
https://www.techspot.com/downloads/5775-3dmark.html
should look like:
View: https://www.youtube.com/watch?v=6IVdtaZdK-Q
This is my result!
https://www.3dmark.com/3dm/42877922
Please help :'|
