When I play some games I am not able to turn the graphics up as high as I think I should be able to. In Fortnite, I'll get around 115 fps on low settings but it will drop down to 30 pretty consistently. I understand that this could just be from the poor optimization on Epic's side, but I'm wondering if there's something in my setup that is causing my computer to run worse. I have updated drivers and that's not the problem. Also on Destiny 2, I can't even run the game on any settings. When I run on the highest settings my computer almost blows up, but there is hardly any difference between the fps when I run the game on the lowest of the low settings compared to medium settings, causing me to think it can't be my graphics card. Also, when I put all of the settings to the highest settings it only uses half of my vram. On Overwatch I can only run low-medium settings and I think I should be able to run more than 70 frames.
On the website for the Powercolor Red Devil RX 590 it says that it recommends at least 600w of power, while I only have 500w, so that could be a problem. CS:GO runs fine at all max settings but why does that get around 130 frames and other games won't run well?
CPU: Ryzen 3 1300x
GPU: Powercolor Red Devil RX 590
Power Supply: Some kind of 500w Rosewill
HDD: IDK but it's 1 terrabyte
MB: Asus tuf b450 gaming pro
UserBenchMark: https://www.userbenchmark.com/UserRun/24175553
CPU temps don't get above 50 degrees on CS:GO and GPU won't get higher than 70 pretty much ever (mostly stays around 50-60.
Parts on PC part picker: https://pcpartpicker.com/user/Magmacream187/saved/#view=hD2q3C (btw that power supply isn't correct, I have a 500w Rosewill power supply)
If I am not under performing, what should i upgrade?
Thanks for any help you can give!
CPU: Ryzen 3 1300x
