Hello All
Thanks for letting me join the forum. I've used this site for guides and to solve issues and its been a great help, However im having an issue with a PC that i am unable to figure out
So, my work had some old PCs they were going to throw out. Seeing it as a waste i aquired two of them for my kids to use for homework etc. I then started to find parts that would be compatible to make them perform better and they can play some games on them also.
Both PCs are HP 500B MT ( i know couple of dinosaurs!) The first one i upgraded fine and it works perfectly, the second one is having a POST issue on startup even though both pcs/upgrades are the same
below are the upgrades to both PCs
KINGSTON SSD HARD DRIVE
GeForce GT710 Graphics card
intel core2quad Q8400 CPU
one pc works totally fine, the second one fails to start once i changed the old cpu to the core2 quad one and then gives me the one short beep and one long beep on startup.
ive checked the Ram seating, put the old CPU back in and it works. I even put the Q8400 from the other pc i upgraded into this one as i know that one works but still the same issue
The only difference i can make is that the 1st pc runs the Palit gt710 where the troubled pc is on the Asus gt710
both pcs are on windows 10 64bit and are on the bios 6.05 (lastest i could find)
I did remove the CMOS battery (but only for 20seconds or so) and replaced with a new battery
im stumped on this one, and i'm hoping someone could help point me in the right direction
Regards
Tom
Regards
Tom
