I recently purchased an ECS K8M800-M2 MB and set it up on the bench with a Sempron 2800 processor and 512mb of suitable ram. All BIOS settings were default.
At first the MB did not POST - then I found the 12V aux PS plug was out 😳
After that all was well - POSTed, booted and ran my XP system fine.
When installed in the case - no POST although the fans were running and HD etc powered on. NO video on monitor etc. I used all the integrated peripherals.
Put MB on bench again out of case - still no POST.
Decided to try a CMOS clear, and then discovered that if the clear plug was pulled from pins 1 and 2, then simply reconnected to 1 and 2 while power on, - instant POST and all runs fine.
If a hard reset, or power off then on again, same problem - CMOS clear plug out and back in - away she goes.
Soft reset from windows OK.
What does the CMOS clr plug do when in pins 1&2? I tried doing a full cmos clear but did not solve problem. If the board is faulty, it is still under warranty, but I am intrigued. Battery? MB fault? Some strange bios setup?
Maltone
Maltone
