[SOLVED] Potential Motherboard problem?
Aug 31, 2019
8
My gaming pc I've been working on for the past year doesn't put any visuals on the screen. Im using a ryzen 3 2200g with a "asrock am4 b450m-hdv" motherboard. I was thinking that using a different mobo would fix the issue. Before I buy the "MSI B350M-PRO-VH-PLUS," I wanted to know your oppinions on the matter.
Has it ever output?
If not:
The B450 boards launched before the 2200G - so it may not have the appropriate BIOS installed, hence the lack of display out.
B350 would, in theory, be worse - as the chipset (and board) is older. However, if it's later produced stock, or used.... it may have had the BIOS updated.
Has it ever output?
If not:
