Power adapter compatibility
Yes, here are the specs for yours:
Total wattage: 65 W
Output voltage: 19.5 V
Output amps: 3.3
As long as the charger has the same output voltage and an equal or higher amperage (which the one you linked does) then you are good to go.
Total wattage: 65 W
Output amps: 3.3
