First, simple question. I have an AMD Athlon Xp 3000+. it runs at about 55-60 C normally. Whats the highest temp a CPU like this should run? I dont want to overheat or anything. I have the heatsink that came with the CPU and thermal paste.
Second, I am having trouble with my RAm and I think it might be my power supply. I just installed another 512mb of ram, totalling 1gb. Should I change the power directed to the RAM? I have been haviong problems. Just a second ago I turned on CS and played for a minute, then the computer randomly rebooted itself. The comp was on for about 2 hrs with no problem after installing the RAM. I have another 512MB stick that apparently doesnt work. When i put it in with the others (dual channel mobo) it gets to windows and either blue screens or reboots as soon as windows starts.
Finally, what amount of power is ideal for my CPU?
whew that was a lot...thanks in advance.
