T Tomos Woolley Distinguished Aug 11, 2014 88 10 18,635 Jun 11, 2018 #1 I have recently built a PC and everything work except I can't turn it off via the power button at the front any ideas why
Solution Sohom Jun 11, 2018 Check if the settings are exactly as in the pic. https://imgur.com/xPLgo4O Control Panel>Hardware and sounds>Under power options select change what the power buttons do;
Sohom Distinguished Mar 6, 2017 1,396 79 20,390 Jun 11, 2018 Solution #2 Check if the settings are exactly as in the pic. https://imgur.com/xPLgo4O Control Panel>Hardware and sounds>Under power options select change what the power buttons do; Upvote 0 Downvote Solution
