Yesterday I opened up my pc and in order to install a fan I had to remove the top part of my Zalman Z11+ case and I did that and installed my fans and after I was done I was putting everything back together and when I went to turn on my pc I realised the power button doesn't press. The button is loose and doesn't actuate. I've since opened up my pc and dismounted the whole power button and I've managed to make it click again and actuate but as I proceed to close up my case the button falls in and becomes loose again. I was trying to figure out how the button actuates and maybe it's because of worn down plastic or something. But I don't quite understand the mechanism to make it click, because if I knew how it worked I could do a little mod on the button to make it work.
Thanks in advance
I can show pictures if needed
Thanks in advance
