Question Power consumption and price which one will be the perfect balance card? Gtx 1060 6gb or Rx 580 8gb?
Jan 21, 2020
I saw that RX 580 have a better performance than 1060, I want it but the power consumption said by others are higher than 580, i like that it is cheaper but, will the price can overtake its power consumption? Is it worth it? I have bronze efficiency psu.
ohio_buckeye
976
229
11,390
28
Should be similar performance. But the 580 will consume more power. Depending on the pricing you are looking at though, for not much more, you might be able to get the gtx 1660 or 1660 super. I just got one of those for 230 US. From what I've seen the performance on that card should be closer to the 1660ti.
If you do go that route, I wouldn't bother with the standard 1660. The super would be close to a gtx 1070 level of performance.
Of the 2 cards you listed, the 580 may be slightly better. But can use over 200 watts of power under load.
