Hello everyone,
Recently, I've noticed that my PC's power consumption is high, and I've always wanted to test it, but I lacked the necessary tool. However, I realized that my Multimeter could do the job.
I checked the amount of current (in amps) my PC drew at idle from the wall, and here are the results I obtained:
(Note: I live in Asia, and the AC voltage from the wall typically ranges between 220V to 240V, so I used 230V as a baseline here.)
I believe that 150W+ at idle is too high for an entry-level system. Even without the monitor, my PC still uses 120W+, which is still very high in my opinion. However, I am unsure of how much it contributes to my monthly electricity bill.
I also have an old i7 Haswell (4th Gen) system that consumes less than half of what my Ryzen system consumes at idle.
So what should I do with these results? Do you think they are accurate? If so, should I consider switching to Intel? I do not require much system power, as I only play games for 2-3 hours a day, and they are typically light games. However, I do leave my PC idle for long periods.
Here are my full system specs:
- R5 3600 + RX 570 + 27 inch 1440p monitor = 0.68A (156W)
- R5 3600 + RX 570 = 0.54A (124W)
- Ryzen 5 3600 (undervolted)
- RX 570
- Gigabyte B450 Aorus Elite
- Corsair Vengeance RGB 8GBx2
- 7x 120mm fans (5 of them have LEDs)
- 2x 7200RPM HDDs
- 2x NVMe SSDs
- Around 5-7 years old Corsair CS750M 80+ Gold PSU
- 27 inch 1440p 144Hz monitor.
