power Consumption with a 2nd GTX 1080 SLI
Ar00gu
Commendable
Nov 17, 2016
13
I've a 750W PSU and am considering a 2nd GTX 1080 for 4k gaming (WoW, FO4, Civ VI, Skyrim SE, mostly). I o'c the CPU and GPU But if it's warranted and beneficial to the upgrade I can curtail that.
Would a PSU upgrade be necessary with this type of upgrade? Would any other type of upgrade(s) be necessary if I did go for a 2nd GPU?
Could I add a 1080 Founders Edition instead? Or could the addition of a lower cost 2nd GPU push me comfortably into 60+ fps 4k gaming.
Thank you kindly.
[Build info]
Intel Core i7 6700K
ASUS Z170-PRO GAMING
Corsair H115i - 280mm Liquid CPU Cooler
16GB DDR4 2666MHz
750W EVGA SuperNOVA
M.2 512GB Samsung 950 PRO
GTX 1080 8GB EVGA ACX 3.0
ASUS PB278Q (for now)
If any other info would help please let me know. Thanks!
Sorry, not at home right now, but I know it's a 750W EVGA SuperNOVA (750 B1) model, which is a 80+ BRONZE type. Sorry if that doesn't answer but it's the info that I have right now.
I found the Corsair PSU calculator page;
http://www.coolermaster.com/power-supply-calculator/
Which gives a component-based calculation of PSU needs quite thoroughly.
