Power-cut while shrinking the drive, now the drive is corrupt. How do I recover it?
Sep 12, 2017
4
I was shrinking my drive because I generously gave 40GB to C drive >_>. wanted to expand and it and while it was shrinking I had an unfortunate power cut now the drive doesn't show up in the file explorer but can see that space on disk management. I tried recovery tools and they seem to find my files but when I hit recover they ask me to open a directory which can hold the data and I don't have any....... I just want my drive back.
Then I'd just wipe and restore the most recent backups of my files.
if that can work it'd be awesome, just a reminder that the partition has some super really important stuff, also, please describe or more step-by-step approach to backing up the file after wiping it, I don't want to lose my data after wiping and nor take risks.
The assumption was that you had been backing up your important files already. The only time you can dependably protect important data is before something bad happens. If you haven't been taking care of backups -- it's an important part of PC upkeep -- your solutions become trickier.
Do you have a thumb drive large enough to hold the data that software recovers?
I could've already recovered everything if I had a drive enough to hold all the data in that drive with recovery tools.
Well, you have your options. I wish you the best of luck.
