Question Power cycle
Likely an error of omission or commision with respect to the connections that have been made.
Update your post to include full system hardware specs and OS information.
Any troubleshooting LED's lit?
Refer to the motherboard's User Guide/Manual to double check that 1) all connections are correctly made and, 2) that those connections are fully and firmly in place.
Take a close look at the motherboard's I/O panel.
Also check the case's front panel connections, Verify per the installation documents.
And lastly: What thermal paste was used and how was the paste applied?
Could be a thermal shutdown.
The ez debug cpu light light red for split sec then dram light light up orange for split second and then vga light lights up but boot light doesn't light up and then computer shuts down and turn on again, the same lights light up
I Tried booting with one stick ram it didnt help. When i took all the ram out the power cycle stopped
Pc specs:
CPU - i3-12100f
GPU - Rx 580 8gb
RAM - Corssair vengeance ddr4 2x8 GB
Motherboard - Msi pro b660m-a wifi ddr4
PSU - DeepCool DQ 650-M-V2L 80+ Gold
I recently tried updating bios on asus b660m board with this i3 and the board got bricked
One of the most common causes of a newly built system cycling on and off like that is that the STAND-OFFS supporting the mobo are installed incorrectly. Look at these two previous post if that might apply.
From Apr24/23
and from Apr21/22
