G GraySenshi Reputable Apr 15, 2016 758 0 4,990 Sep 8, 2017 #1 I have a a8 3850 what is the max power draw CPU max vs CPU max plus it's intagraded graphics. And what would the difference in power draw for a gt 1030
Solution T T Tyler Paul_1 Sep 8, 2017 If you want to know download HWMONITOR and you can check your power consumption there (if this helped please make best answer )
T Tyler Paul_1 Prominent Jul 4, 2017 182 0 760 Sep 8, 2017 #2 gt 1030 has a tiny amount of power draw(30w) an a8 3850 MAX power draw is 100w Upvote 0 Downvote
G GraySenshi Reputable Apr 15, 2016 758 0 4,990 Sep 8, 2017 #3 But isn the 100 combined with the CPU tho Upvote 0 Downvote
T Tyler Paul_1 Prominent Jul 4, 2017 182 0 760 Sep 8, 2017 #4 yes the a8 is the cpu+ graphics (100w) Upvote 0 Downvote
G GraySenshi Reputable Apr 15, 2016 758 0 4,990 Sep 8, 2017 #5 So with intagraded graphics how do you know what amount is CPU draw and what is gpu draw Upvote 0 Downvote
T Tyler Paul_1 Prominent Jul 4, 2017 182 0 760 Sep 8, 2017 Solution #6 If you want to know download HWMONITOR and you can check your power consumption there (if this helped please make best answer ) Upvote 0 Downvote Solution
