Power/HDD/RESET wires too short on Antec 900 help
aford, they may not be long enough, especially if the front panel connector is on the lower edge of the motherboard. I know. I have 3 Antec 900's.
04, one thing you can do is to buy extension cables. I bought mine at frozenCPU.
Ok, I may be wrong. I haven't used that model yet.
The last build I just did had the antec 300, and they were proportionate length for the case size. Most motherboard front panel ports are at the lower edge of the board. Which is why I assumed a good company like Antec would think of that, and make their cables long enough.
04181979XXX
66
thanks ill buy the extension cables
