Hi there,
I have an issue with a system I built last year, so it is about 14 months old. This problem has occurred randomly since it was built.
The problem is this: when the power button is pressed, the system refuses to boot. The only way to recover from this is to disconnect the power and all USB cables and then wait for a while. The "while" can be as little as 5 minutes or as long as over night.
When the problem occurs, after the power button is pressed, the fans spin and light up (although on a couple not all LEDs activate), CPU cooler block lights up and the memory LEDs light up (both cycle through their default colours). But the system is otherwise dead. Nothing on the screen, no BIOS message. A couple of times I've tried leaving it for a while, but it never boots from this point.
Components:
MSI X470 motherboard (GAMING PRO CARBON AM4)
Ryzen 7 2700X with Corsair Hydro H115i liquid cooling system
G.Skill Trident Z RGB 32GB (2 x 16GB) DDR4 3200MHz for AMD
Case: Thermaltake View 71
Update: Power supplies:
First one I tried was a Thermaltake Toughpower Gold 650W (TPD-0650M)
The one in it now, which is also a bit older than the 650, is an OCZ ModXStream Pro 700W (OCZ700MXSP).
Disks: Boot - Samsung 960 512G NvMe, others: 2 x WD 4TB, 1 x Seagate 3TB
Video is just an old nVidia of some sort, this is next to get upgraded. This was working fine in my previous system so was not replaced, to keep the initial costs down.
I also have 4 Corsair LED fans in the case, with separate USB controller.
Another issue the system has, and I'm sure this is related, is that whenever I use the USB ports on the back of the mobo, for example an external hard drive or SD card reader, the device will drop off, and reconnect, and drop off, and reconnect ad infinitum. Time between drop-offs is random. Reconnect is usually immediately after the drop off.
I initially built the system with a 650W semi-modular power supply, but changed that to a 700W modular after the initial few occurrences of the problem. Problem still occurred/occurs. Sometimes often, sometimes it would go for a few weeks without occurring.
I then found out that the G.Skill RAM I had in the box (F4-3200C16D-16GTZR) was not "AMD optimised". As I'd planned to add additional memory, I bit the bullet and replaced the two 8G DIMMS with two 16G DIMMS that are AMD optimised. Basically the same type only higher capacity and optimised. The problem disappeared after this. Or so I thought. I had probably 6 months of use without the problem occurring, and then suddenly it's back. Now pretty much every time I power it on unless I do the whole disconnect thing beforehand. I've gotten to the point of disconnecting everything when I power it down just so I'll have a better chance of it powering up the first time when I next use it. Usually when I'm home I will leave it running, and only power it off during the week when I'm working and don't have time to use it.
The other thing that is gnawing at me is that the case, a Thermaltake View 71, is all painted inside, and the screws provided with it are all black lacquered. I'm just wondering if it's a grounding issue.... or perhaps temperature-related? Now that it's coming into summer here in Australia, and it's been stinking hot lately, the problem seems to be more prevalent. During our winter there were no occurrences (past 6 months). The room where the system is is no hotter than the rest of the house, but it is certainly warm now.
Anyway, I guess the next thing would be to replace the power supply but I'd seriously doubt that the one that's in it is being taxed at all. Apart from the USB dropouts, once it's running it doesn't seem to have any other problems, certainly not starving for power. If I did replace it, what do you think would be a good capacity? 850W, 1000W?
Any suggestions/theories much appreciated.
Cheers,
Pete
Components:
Cheers,
Pete
