Question power on problem
Oct 7, 2019
4
hi guys i have an issue with my pc .
i just build it and when i first booted it worked like a charm , then i fixed some cables and maybe kinda mooved it a little i dont know and when i booted it again my fans started to blow hard and the pc was shuting off and opening (looped). after i mooved some cables and reujust my 2 dim ram stiks when i opened it one of my case fan start working immediatly and the other 2 had 5 sec delay. also the video signal has the same delay . is there something wrong ??
why it dosent work like the first time wich was buttering smooth ???
windows 10 64bit
Asrock B450M Steel Legend
ryzen 5 3600
gtx 970
1 ssd
1hdd
1 watercooler corsair h60
3 case fans
ps : i also have a video but i dont know how to post it
Ralston18
Update your post to include full system hardware specs and OS.
Open the case and very methodically and carefully check all cables and connections.
First to ensure that they are correctly located and second to ensure that all are fully and firmly in place.
Any beep codes or LED lights?
Reactions: bill1994
Oct 7, 2019
4
i just updated , i did what u said the mmotherboard have lights led , the pc works but it takes time to open cause of the delay .
only one fan starts to spin when i power up the other two take some time and i dont know why
also do you know how to post , upload a video here ???
Ralston18
