Question Power Planning for ASUS DUAL-RTX3070-08G
Imacflier
579
27
19,090
Good Morning, Guys.
I am going to use the ASUS DUAL-RTX3070-08G paired with an HP EliteDesk 800 G5 Mini.
Since the HP EliteDesk 800 G5 Mini does not have a PCIE slot and is physically smaller than the HP EliteDesk 800 G5 Mini, the 3070 must be mounted externally on an m.2 to PCIE adapter.
The RTX3070 has a TDP of 230 Watts, far in excess of the capacity of m.2. The adapter is designed to accept an Alienware power adapter of 220 Watts.
Since 230 Watts > 220 Watts, I thought I would use Afterburner to undervolt the RTX370 down to the power available.
I have literally no experience with either the RTX3070 or with undervolting, which leads to
Question #1: Do any of you more experienced folks have any idea on just how much I must reduce the voltage to reduce the RTX3070 power demand down to 220 Watts?
But wait! I would expect that, when playing AAA games, the RTX3070 will demand power in excess of the 230 Watt TDP, which leads to
Question #2: Can I safely ignore these power demand spikes, and if not, how much power demand do I need to plan on (This is all 12vdc power)?
Now I am quite certain you all want to know why on earth I would resort to such a Rube Goldberg lash up! The answer is simply that I already have ALL the parts sitting in my parts drawer and I would MUCH rather use them than let them gather dust or (gasp) pursue a different solution!
Please advise me if you can.
TIA,
Larry
You might want to understand that the RTX3000 series was notorious for high transient load spikes;
View: https://www.youtube.com/watch?v=wnRyyCsuHFQ
leading people to reinvest on PSU's with overprovisioning. People who owned an RTX3090 were later asked by reviewers in the industry to get a 1.2KW reliably built PSU. That wattage number trickled down as you went down the stack eventually leading users to have an 850W reliably built unit for an RTX3070. With that I see your endeavor with strapping that GPU onto an uSFF(that shouldn't have that GPU) to be met with a lot of rebuttal from the platform itself.
Instead of crippling powerful hardware to fit inside a shoebox, I'm sure you could build a regular desktop(SFF)platform, sell it or hand it down to someone in your family tree and call it a day instead of dropping resources for something that shouldn't exist.
My 2 cents.
Reactions: skitz9417
[COLOR=rgb(0, 0, 0)]Lutfij[/COLOR],​
Thank you very much for your reply, especially for that link! I rather suspect I will have to use a substantially larger 12 vdc supply.
I know that most folks do not approve of my approach, to which I can only reply "Different strokes for different folks!"
I have used this approach, successfully, twice before, although with lesser GPUs, and with the appropriate changes see no reason not to proceed.
I am trying very hard not to make this thread not raise any member's hackles, btw.
Thanks again,
Larry
