Power problem with new Asus PC
Hamdeath
76
Hi,
So I just bought a new PC (spects at the end of the post).
I played 2 games on it for now:
1. Dark Souls 3 Maxed graphics (no problem)
2. Battelfield 4 Maxed graphics (after about 2 or 3 minuts, Pc shuts down because of power issues)
The spects that are on the website from where I bought it are like this:
OS: Windows10 64bits,
MotherBoard: ASUS H110M-K,
CPU: Intel i7-6700,
GPU: ASUS Turbo Nvidea Geforce GTX1060 6Go,
Supply: 450W,
You can see the PSU spects on the bottom of this website (sorry it's on frensh):
http://www.sbsinformatique.com/prod-18000-PC-Gamer-Titan-Light-Gaming-TLG7860
Thank you.
Even though your computer would only likely draw around 330 Watts on average, that would probably be a huge thing for that power supply. As it seems like it's quite a poor quality one. I would suggest upgrading it, even if it isn't causing your issue, which it probably is. The only thing I could suggest is going to the bios and resetting the settings to factory default settings.
Do I use MSIAfterBurner for that?
Sorry but there's no sticker on it from the outside (I can't open the case and see if there is one from the inside)
