Power saving mode
Yes. All it will do is turn down your display brightness and (possibly) scale down your CPU/GPU's performance. Should have no effect when watching movies or browsing the web, but may slow you down while gaming. Will also generally turn off your display and/or put your laptop in hibernation if you are idle too long. Something to keep in mind when watching movies, but you can adjust this in your settings.
Basically just means that your various components will not be running at full capacity, not that they should need to for your purposes. If you try to multitask too many things at once, then it might become an issue.
