Power socket made a buzzing electrical noise when I turn on the Power supply unit
Zorc
Hi. New here. So my problem is with my PSU. Gigabyte Hercules X 580. It suddenly made a slight pop sound one day when i change places and there was no visual damage on the psu or the mobo. but the psu can no longer be used. after replacing it through warranty, i tried testing it on the mobo only, removing the graphic card and hdd. when i turn on the power button on the psu, the power socket made a buzzing electric noise and the psu is broken again 🙁 what's causing this?
remove surge protector and plug your pc directly to your wall outlet,surge protector maybe faulty.
Forgot to mention I was using a surge protect extension so the power socket was fine and can be used normally but only has problem when i plugged in the PSU for my pc
