Hi, first post here. Been a long time lurker but never really been able to answer or need any specific help before. That changed yesterday.
I recently upgraded my GPU from a GTX480 SLI setup to a single GTX 780. Not had time to play with it until yesterday. I was playing Metro Last Light for around 1.5hrs when my system just shut down all of a sudden. No crash, no lag, no bluescreen. Everything was fine then it turned itself off. I then turned it back on, but as i did i could smell burning so quickly hit the power button.
I opened the case and couldn't trace any hint of where the burning came from and it disappeared pretty rapidly. Now i had been monitoring my temps and the GPU never went above 58C on auto fan profile, my CPU stayed in mid 50s. The RAM felt pretty hot but i thought that was normal under stress.
Ran Memtest86 just in case it was RAM and it came out fine. Checked blue screen view for error log but had nothing.
Played again later for another hour to try and reproduce the problem but nothing. I am at a bit of loss here, if any of you guys could point a light on this i would hugely appreciate it the help. Play games on this machine but also use it for work (3d rendering, overnight sometimes) and i would rather avoid this happening when i am not about.
There is a little dust in the case but nothing drastic. Its possible some could have got singed or maybe I bumped the power lead? Hoping it may have just been random 😀
My system:
Intel I7 930 stock speed
P6T deluxe mobo
MSI Gaming GTX 780 3GB
12GB Gskill Ram
Tagan Superock 1000W PSU
Coolermaster HAF 932
If you need any other info just ask. Again, thanks for any help and advice.
My system:
P6T deluxe mobo
12GB Gskill Ram
