Hi, this is my first time ever building my own computer and I need some advice about the PSU I currently have and if it is going to be sufficient enough for my build. I built this computer about a month ago and it has been up and running with no problems whatsoever. I'm proud of myself for putting this build together with help from only youtube, forums and guides all over the internet and it working on first boot and every boot since.
Asus Z87-Pro V-Edition MB
Intel i5 4670k @ 3.4Ghz CPU
8GB DDR3 1600 G.Skill Ripjaws X Low Voltage 1.35v Ram
EVGA GTX 770 Superclocked ACX Edition GPU
| Samsung 840 EVO 120GB SSD
Western Digital 1TB HDD
Wetsern Digital 250GB HDD
***Rosewill 630w Green Series PSU***
So when I originally bought all the components I was planning on getting a video card that required less power(GTX 660), hence only having the 630w PSU. But a few weeks later i found i was able to get the GTX 770. And I was just too excited about it that the question of if my PSU will be good enough flew right over my head, until now. Although the minimum EVGA shows in the manual is a 600 watt PSU for this GPU. Sucky thing is the 30-day return policy is up on it now, that's why I need some opinions.
With everything I have already installed in my system it also includes in my Rosewill Blackhawk Case: 5 led fans, and 3 non-led, a front multi-SD card reader, a wi-fi pcie card, a firewire pcie card, 1 dvd/cd burner, and a couple usb external hard drives, along with mouse/keyboard (just trying to list everything i have so you can determine power usage). And also a program that came with my motherboard, the ASUS AI Suite 3 overclocked my cpu up to 4.6ghz with the 4-way optimization just fine, but I have been only keeping it at a max of 3.8ghz on its preset turbo mode because I'm no expert on this stuff yet. My system has not yet failed or crashed due to insufficient power. But almost everything I have found online so far says that it is just barely enough. I don't want to risk continuing running my computer almost all hours of the day and playing graphically intense games all the time if there is a chance my PSU will fail from not being big enough and fry my brand new components. Some sites make me feel better about it and others say it's not enough. So i need some real opinions/advice.
What should I do? Spending another $100 to $150 on a bigger PSU I am completely fine with doing. Then I'm out $60 for the previous one and stuck with it. But, I'd rather do that though then risk ruining the $1600 worth of components I've already put into it. Thank you in advanced for anyones input.
