Question Power supply and gpu question
Feb 28, 2020
5
I just bought the 2080ti msi gaming x trio. This card requires two 8 pin connectors and one 6 pin connector. My power supply does contain all the connectors needed. The issue is in the cables themselves. Every cable that came with the power supply is 6 to 8 pin. I figured I could buy a 6 pin male to 6 pin male but nowhere sells such a cable, so I have just 6 pin to 8 pin. My question is can I plug in the 6 pin side on the power supply and then run it to a 8 pin on the gpu. Then the other connections would be 8 pin to 6 pin and then 8 pin to 8 pin from power supply to gpu.
I happened to just buy my current supply on Boxing Day so it’s new, I was hoping not to have to buy a new power supply. I did find a 6 pin to 6 pin on amazon.com but that’s going to cost me duty and be a while to arrive.
