Power supply and graphics card compatability?
oddllama
11
Hello, I have recently bought this computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883155414
And i am looking to upgrade my power supply and my graphics card this is the PSU I'm looking to purchase :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817553013
And this : http://www.newegg.com/Product/Product.aspx?Item=N82E16814202002
is the Graphics card I'm wanting to buy. my main concern are the two being compatible with each other and of course my motherboard. So I'm hoping you guys can help me out?
SAPPHIRE 100358L Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card for $114.99 ($99.99 after $15.00 rebate card if purchased from Newegg.com or Newegg.ca between dates December 1, 2012 and January 15, 2013.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202011
but to be honest, dell use good psu's, you dont need to upgrade the psu to use that graphics card. in fact you could run a 7770 no problems. Open up the case and look at the specs on the current psu, particularly the wattage, and the amps available on the 12v rail(s)
oddllama
11
It currently has a 300 watt psu installed and the graphics card requires a minimum of 400 watts and i cant seem to find a good graphics card that can be ran with 300 watts much less a low profile one.
The link that you provided for your system shows that you have the mini-tower version.
That version is able to handle full height PCI-E x16 graphics cards with a length of up to around 9.5 inches before the hard disk drive cage interferes.
If you owned the slimline version (i.e. Inspiron 660s) then you would be limited to low profile graphics cards.
oddllama
11
Thank you . It saying the mini-tower confused me.
There may be one or two Radeon HD 7770 GHz Edition graphics cards within that price range.
You will still have to upgrade the power supply though if you decide to get one of these cards.
oddllama
11
Thank you so much. you both have been extremely helpful.
