J JvZ2101 Honorable Mar 4, 2016 59 0 10,660 May 1, 2016 #1 Hi, I am looking for a Tier 2 600W power supply for a decent price, I thought between 60-70 euros. I don't know if they exist, but if they do and you know a good PSU, please respond. It will be used with a R9 380 or R9 390 and Intel i5 6500.
J jimmyEatWord Respectable Mar 10, 2016 1,358 0 2,660 May 1, 2016 #2 if you are going to use the above mentioned gpu's then you gotta buy tier 2 , tier 1 is gonna be too expensive for you with 8 pin connectors Upvote 0 Downvote
J JvZ2101 Honorable Mar 4, 2016 59 0 10,660 May 1, 2016 #3 jimmyEatWord : if you are going to use the above mentioned gpu's then you gotta buy tier 2 , tier 1 is gonna be too expensive for you with 8 pin connectors Yeah I don't know why I put tier 1 in my question. I would only expect a tier 2. Edited, thanks Upvote 0 Downvote
Archaic59 Polypheme Jan 6, 2015 10,037 646 69,240 May 1, 2016 Solution #4 Look for Seasonic S12II 620 in your price range. Upvote 0 Downvote Solution
