power supply cant turned on when pressing power button in case,but can turned on when i switch at psu button
electricsnake
125
is i have problem with my psu?because my psu can only turned on when i use switch at power supply not with my power button in case
beside that i want to ask,if i shutdown the computer and then after my pc completely shutdown,is it fine to directly just turn off the electricity?or i must turn of the switch( on and off)in my psu first then turn off the electricity?
the question is there is any problem with my psu?because i cant turn on my pc with my power button,i only can turn it with switch the button at power supply from on to off then on again
how to do that?is that touching that 2 small pin at mobo using screwdriver?
i can start up my pc,but i must turn on->off->on at my power supply switch...so if i do like u told me,is that any chance i can start up my pc using case switch?
