T trucker1970 Honorable Nov 14, 2013 1 0 10,510 Nov 14, 2013 #1 I have an acer ax3400g-u4802 ps is bad can I replace it with a power supply from an acer ax1430g-uw30p they are both 220w but not sure about the pins
lonewolf7 Splendid May 6, 2013 5,113 2 24,965 Nov 17, 2013 #2 Yes I think they would match. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,621 1,780 159,590 Nov 17, 2013 Solution #3 They are similar specs so the change should be fine. Upvote 0 Downvote Solution
