Long story short , power supply in old PC died ( Brown smells ) Purchased new PSU, (Civis brand- 700 Watt) Worked fine.
Old PC is very old needs replacing.
Planning to use newly purchased PSU as part of new PC build.
New motherboard is an Asus Rog Strix X470 I gaming ITX.
Motherboard has standard 24 pin and 8 pin EATX.
My power supply has one 24 pin and one 6 pin and one 4 pin 12 V EATX.
Problem, there is no 8 pin 12 V EATX
I'm thinking I will trim the 6 pin connector down to just 4 pins and use it with the other 4 pin connector to fit into the 8 pin motherboard connector.
The cables are the standard yellow + and black - and all seem to come from the one point inside the PSU circuit card.
The PSU is rated at 700 W and my total build is rated 340 Watt.
Do you see any problems doing this. ?
Strange thing, on opening my PSU I found a gadget.
It appears to be a small transformer about a 1 inch square cube attached to the removable cover.
Not connected to anything and positioned over a blank area of the circuit card over which it is located. Wish I could post a photo of it here. Absolutely no writing , part number or anything on it,
Any ideas,,
Looking forward to all comments , Thanks. Tom
Any ideas,,
