Power Supply Connectors Look Bent
I never did anything weird with the connectors. Just plugged them in. I'm also having to rma it because it's making a burning smell and when I looked inside the capacitors are bending.
Out of curiousity, is it just that connector that's bad? Is that to the GPU? What GPU?
The reason I ask is that if that's the only connector that's showing it's been handling a lot of heat (current), then maybe the GPU is faulty and drawing more power than it should, and the PSU is doing its best to keep up. RMA the PSU regardless, but I'm wondering if you'll still have an issue.
Pretty much all of my connectors are bent.
Latest posts
