Splas0rr :
Well superflower makes the Malin components for EVGA but EVGA makes modifcations to improve performance and Seasonic are really good making PSUs but if we are talking 150 $ range nothing comes close to EVGA SuperNOVA P2 750W platinum or titanium rated EVGA PSU´s is unmatched in performance its not fair to compare the GQ series PSU´s with Seasonic premium models but P2 or T2 series from EVGA is probably best PSUs on the market and it comes with a 10 year warranty defently my recommendation 96 to 98 % accurate power supply across the board its about 150 $
I didn't compare Seasonic PRIME series to the EVGA GQ series. I just suggested a great PSU to go with. You sound like an EVGA fanboy by stating such a thing.
Still, let's see how EVGA 750W P2 PSU stands up against PRIME 650 80+ Titanium and if it really is better as you say it is.
Since EVGA 750 T2 does cost more than $150, i won't include it to this comparison,
pcpp: https://pcpartpicker.com/products/compare/jBZ2FT,9wcMnQ,nn648d/
Highest efficiency (higher is better)
Seasonic PRIME 650 80+ Titanium: 94.16%
EVGA Supernova 750 P2: 91.45%
Average voltage regulation (lower is better)
Seasonic PRIME 650 80+ Titanium: 0.04%
EVGA Supernova 750 P2: 1.6%
Ripple noise on full load (lower is better)
Seasonic PRIME 650 80+ Titanium: 6.2mV - 12.2mV
EVGA Supernova 750 P2: 9mV - 17.2mV
Hold-up time (higher is better)
Seasonic PRIME 650 80+ Titanium: 35.3ms
EVGA Supernova 750 P2: 22.1ms
Fan noise at full load (lower is better)
Seasonic PRIME 650 80+ Titanium: 28.3 dB(A)
EVGA Supernova 750 P2: 46.3 dB(A)
Warranty length (longer is better)
Seasonic PRIME 650 80+ Titanium: 12 years
EVGA Supernova 750 P2: 10 years
Sources used:
Seasonic PRIME 650 80+ Titanium,
JonnyGuru:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=493
Tom's Hardware:
http://www.tomshardware.com/reviews/seasonic-prime-titanium-650w-psu,4690.html
EVGA Supernova 750 P2,
PCPerspective:
https://www.pcper.com/reviews/Cases-and-Cooling/EVGA-SuperNOVA-650W-and-750W-Platinum-Power-Supply-Review
Tom's Hardware:
http://www.tomshardware.com/reviews/evga-supernova-750-p2-platinum-psu,4566.html
While both PSUs are great units, Seasonic unit is a bit better. For an average consumer, the ripple noise, hold-up time and voltage regulation usually doesn't matter. What matters is the noise output and warranty length. And for some, efficiency too.
