Hello,
I have an issue with a server power supply which completely fails to run and power the server when the underlying ups in on battery.
This can occur when the ups run a self-test, resulting in a hard reset of the server or if the ups is on battery, then the server is flicking/buzzing and going through a power reset multiple time per second (does not look good at all).
The PSU is : AcBel 550W redundant PSU (load is about 80w)
The UPS is : APC Back UPS Pro 1500VA + external battery extension
Also weird: when the UPS go on battery, other equipements connected to this UPS stay online (router, wifi access point), so that seems to point at the PSU.
I tried swapping the PSU with another spare I had and the behavior remains the same.
Any idea what could be the cause of this? Seems crazy that the PSU can't run at all while on UPS battery ...
Regards,
Regards,
