Hey,
I am refurbishing a cooler master centurion 5 case. The power supply is top mounted, and what I was originally going to do was drill some holes in the top of the case, and mount the power supply fan up, so it would draw air in from the top and exhaust it out the back. But, after a bit of thinking, I realised that because I will also be drilling some more holes for a 120mm fan to go next to the power supply, to exhaust air out the top, that the power supply fan would just draw in the hot air from the exhausting fan, which wouldn't really cool it down. I could mount the power supply fan down, which could act as another exhaust technically, but that would still be using hot air. Which way should I mount the power supply fan?
Thanks
Afford
Thanks
Afford
