Power supply fan replacement
maxwellmelon
Dignified
Oct 2, 2013
2,515
631
pinout for a 3 pin connector
https://www.bing.com/images/search?q=3-Pin+Computer+Fan+Wiring+Diagram&view=detailv2&&id=AD2DD1309B2B9970456EA7BECFDAC405F2EE6BDE&selectedIndex=0&ccid=y5wrpNhM&simid=608027934062936305&thid=OIP.Mcb9c2ba4d84c85dbac694462b84bc34eo0
if you able to line up the right two pins (the power and the ground) it will work. the third pin is just to report fan speed so its not needed.
fan speed doesnt mater as it does not actually say how much air it is moving. so its hard to say if its ok in that reguard.
Quantum_3
Commendable
Jun 15, 2016
39
Thanks, I ended up pulling the wires out of the 3 pin connection and wiring them up to a 2 pin connection that fit perfectly.
Similar threads
