S sandysweet Reputable May 23, 2014 2 0 4,510 May 23, 2014 #1 the fan in the power supply of my Dell xps 7100 is making a squeaking noise until I tap the side of the unit then it stops....is this fan replaceable?
Solution Ubrales May 23, 2014 sandysweet : can I use any power supply that fits or is there a specific replacement? Any ATX power supply will work and fit. Get a good brand like Seasonic, XFX, Corsair HX or AX. - wattage higher than what you have now.
Ubrales Polypheme Dec 3, 2009 13,234 8 61,465 May 23, 2014 #2 Yes it can be replaced. However opening up the PSU and replacing the fan is tricky. Replace with an fan of identical or slightly better CFMs. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,084 2 106,960 May 23, 2014 #3 Replace the whole power supply. The Dell is junky anyway and will cause serious problems down the track Upvote 0 Downvote
S sandysweet Reputable May 23, 2014 2 0 4,510 May 23, 2014 #4 i7Baby : Replace the whole power supply. The Dell is junky anyway and will cause serious problems down the track Can I use any power supply that fits or is there a specific replacement? Upvote 0 Downvote
Ubrales Polypheme Dec 3, 2009 13,234 8 61,465 May 23, 2014 Solution #5 sandysweet : can I use any power supply that fits or is there a specific replacement? Any ATX power supply will work and fit. Get a good brand like Seasonic, XFX, Corsair HX or AX. - wattage higher than what you have now. Upvote 0 Downvote Solution
