power supply for ZOTAC NVIDIA GeForce GTX 970 4 GB GDDR5 Graphics Card
duke_k1
in http://coolermaster.outervision.com/ total power calculation 326 watts and I'm using cooler master 450 thunder, is this psu will work fine on games ultra setting game like battle field 4 ? and yes i'm using 4th gen dual core cpu g-3220t also 32 gb ram ddr3 also i use to work on aftereffect and 3d max
thanks
PSU calculators are not to be trusted, aside from PCPartPicker. You need a 500W PSU for a 970.
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($49.99 @ Newegg)
Total: $49.99
Generated by PCPartPicker 2015-12-27 07:13 EST-0500
Also, your 970 is being severely bottlenecked by that Pentium. There is no way it can utilise 32GB of RAM or even half the power of the 970. Change it to an i5 4460 for optimum results.
Total: $49.99
