jankerson :
Sure it does since he couldn't turn the PC back on until he unplugged the graphics card.
Even if the card was bad the PC would turn on... Might not boot all the way, or not have graphic on the display, but it would run.
Removing the extra draw to the PSU and it turned back on.
This is patently false. Again, one does not necessarily have to do with the other. I've literally seen HUNDREDS of systems that would not boot or even power on because of bad cards, graphics cards OR other types of PCIe cards as well.
In fact, I've also seen many instances where the card was bad and even unplugging it wouldn't allow the system to start or in some cases even power on. The card had to be actually removed from the motherboard for it to show any signs of life at all.
So your assumptions are not backed by fact. You COULD be correct that the PSU is bad, I am not disputing that, but to simply assume that is the problem and that nothing else COULD be, is not how we do things.
Good choice on the PSU. The G2 and G3 series EVGA units are very good. Plus, they have a fantastic warranty.
Make sure to go register it immediately and do not forget to do everything they ask you to do as far as providing the documentation. I don't know if the G3 units are the same as my G2, but it had only a 7 year warranty unless you registered it within 30 days and provided all the documentation. If you did that, they increased the warranty to 10 years. When I purchased it it SAID 10 year warranty, just like the G3 does, but that was only if you registered it within 30 days with EVGA, otherwise it was only 7.
Let us know if that cured the problem or not. I would have preferred to help you determine for certain that the PSU was the problem before buying another one, but you've got a MUCH better unit now so it's a moot point anyway since you already bought it. Kudos on getting a good unit instead of another mediocre one that simply had a higher capacity.
