Question Power supply from 2014 ..will it work with RTX 3070?
Juular
Commendable
Mar 14, 2020
881
204
1,440
93
If it's never been used it should be fine and quality-wise it's a good one. You may wish to read this review.
The OP have linked HX Gold, not HX Platinum, there was no HX Platinum in 2014. And a PSU sitting on the shelf for 7 years is hardly better than it being used for the same 7 years, if not worse.
I have a question ..will it work with Rtx 3070???
If you cannot buy a new PSU right now then just try it, as long as it indeed works with RTX3070 then it's fine for the time being. But it's not a particularly good PSU for today standards, and the fact that it's also 7 years old doesn't help.
Reactions: Od86x
