Power supply help?
Most of Antecs power supplies are made by Seasonic. Seasonic is one of the best in the business. Antec has some units made by Delta ,CWT, FSP and Enhance. The Delta units are good, the CWT units are suspect as CWT tends to be hit an miss quality wise. FSP and Enhance isn't bad most of the time. The Seasonic built Antec HCG 520m is alot higher quality than that CWT made CX600 you have in your signature. The CX series suffers from cheaper secondary caps with a short life span and high failure rate.
