Power Supply Help
Joorj Pagarigan
59
Hey guys Just wanna ask if My CX500m will be sufficient.
cause im buying a Pentium Anniversary Edition and ill overclock it
with my gt430(cause low on budget soon to upgrade)
ill also overclock my gt 430 will it be sufficient? thanks in advance.
For overclocks I would suggest staying away from Corsair's lower priced GPUs. They simply aren't built as well, but are reliable for non-OC systems.
I've heard amazing things about the Antec High Current Gamer series, and not a bad word in the mix. Check those out if you're interested in replacing the PSU.
You may get an decent overclock, you may not. The parts may refuse on you because of "dirty" power, or just because they got the bad draw of silicon.
look into EVGA supernova PSU with at least 650 if your looking at overclocking.
Remember pending on your build plan make sure you get a decent psu that has decent capacity.
For example: if your planning to get GTX970 in future 500W will be enough but a minimum of 750W 80+ Gold is needed especially if your planning to overclock.
this is my current rig
Athlon xII 455
gt430
4gb ddr4
cx500m
64gb ssd
500gb WD Green
and im upgrading and getting ( 4gb ram gt 430 cx500m and 64gb ssd)
1tb hdd
cooler master seidon 240m
Pentium D anniv edition
z97-AR
and Soon when i got the money( go for gtx970, i7-4790k, 250gb ssd, and 750w seasonic); i just need to give my athlon and board urgent :))) TIA guys ^_^
