Power supply help
calebrios02
Commendable
Dec 5, 2017
8
I'm getting a new GTX 1060 and I would like a 500w+ psu (I plan on upgrading my cpu) but I can't seem to find any psu's with a 6 pin connector any recommendations would be amazing
you can get a evga 500b or corsair cx550 if you are budget tight, if you have more budget
seasonic focus plus 550w, corsair rmx 550 and evga 550g3 are excellent PSUs.
I think that what you will find more of these days is the 6+2 pin layout. It allows you to use the 8 pin if you need it, but if you don't 2 pins separate and just sit to the side allowing you to use only the 6 pins. It allows makers to get away with having less cables, which is good for cable management, but you'll have to get creative to hide the little 2 pin connector hanging off of it if you are looking to make a super clean windowed PC.
MERGED QUESTION
Question from calebrios02 : "Looking for a good power supply"
