Power Supply help!
jtrueppel
11
Ive got almost everything picked out for my first build, but I dont know which power supply to go with. I was thinking 630W but I need clarification. If you do need to know, I do plan on overclocking GPU and CPU. GTX 1070 Founders Edition is already purchased, so cant change that.
Specs below in link:
https://pcpartpicker.com/list/Y7D2kd
I wouldn't recommend the EVGA BQ. Its fine for lower end builds but because you will be overclocking both CPU and GPU, you should be looking at something higher quality.
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($60.81 @ B&H)
Total: $60.81
Generated by PCPartPicker 2018-06-19 03:25 EDT-0400
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($81.99 @ SuperBiiz)
Total: $81.99
Prices...
Total: $60.81
Total: $81.99
Generated by PCPartPicker 2018-06-19 03:27 EDT-0400
Either one of these should work fine. The G3 has mixed reviews, people are complaining about the fan noise. That is why I recommend the G2. the SuperNOVA G2 also has a $20 rebate right now so I would get that.
You would probably be fine with a 550W PSU too because the total power draw of your system stock would be around 400W and with overclocks it would vary from 450-500W. I'd just go for the 650W for the extra headroom, peace of mind and possibility of upgrading to maybe an 8700k in the future / 1080Ti and overclocking those too.
