[SOLVED] Power Supply Missing Cable to Dedicated graphics card
its a dell. they only come with the cable they absolutely necessarily have to have.
You waited 5 years to answer? are you still waiting?
Dell towers aren't really designed for upgrades. Especially the power. It is the bare minimum needed to run parts. It might be different in their Alienware models.
It sucks to buy something and then find it doesn't work in what you have.
Oh and yes, I go through many new parts since 5 years ago. I have upgraded to a blazing fast 8th generation celeron intel processor, and a gtx 1050. everything works fine. can play rust and gta ,and eft at max settings 1440p at 100+ fps.
