WOW you turned that one around real quick
if you read around the forum for my posts you will find that i am ALWAYS at the end of the argument against needing such high power for pc's. i spend a lot of time here doing the same math i did for you arguing against these same people you obviously feel (as do i) are out of line. i also argue regularly against those same folks who like to argue that anything but a top tier psu will melt down, burn down you house and maybe even your whole neighborhood.
i argued here that the psu in question does not meet the op's needs and showed the math to back it up. i did not say the psu was junk or that one needed 1000w for this system. all 500w psu's are not the same i can show you a top tier one that would have had the needed 12v amps but this is not that psu. i simply showed why this psu would not work for the needs of the op and offered alternatives at the same etailer he was using. you disagreed with the numbers i used so i showed you where i got the from. i redid the math using your numbers and i still would not recommend using this 500w psu at ~90% as a long term solution when there are better options available in the budget of the op.
again take a look around and realize who is on your side and who is not. had i seen this thread you speak of i would have jumped in real quick and tried to add some reality to the discussion. i know the frustration you feel as i try to shoot down these folks myself (and i am sure i could name a handful of the same regular posters who are out of their mind with psu recommendations that you run into). if you don't agree with what i suggested to the op, show why please and try to keep this thread separate from whatever other threads are out there. we do the op no service by continuing arguments from other threads (that i was not even part of) that do not pertain to his specific issue.
you said you run a similar card on 500w and i showed that the card he has is at least 50w higher power usage than yours. this takes the psu from "would work fine" as you suggest to "not quite strong enough" as i suggest.
i'm pretty sure the op got the 600w evga anyway and moved on which is good enough for the pc and will fill his needs fine.
edit: and if you look at that review you posted. they showed that the psu was indeed just above 80% efficient at full load as i assumed. yet another reason this psu would not work at 90%+ capacity in the long run. it is not even that efficient. i am in now way saying you don't know what you are talking about or anything like that. i am simply saying in this case, the op needs a different psu that that 500w evga he asked about.
