Power supply PLEASE HELP
Vinn_Spiffin
Commendable
Jan 4, 2017
12
So a friend of mine is on a budget of 300 dollars. He has an old gaming computer with ddr2 so obviously he needs an upgrade to motherboard ram and gpu. The thing im not sure about is the power supply. This is the build.https://pcpartpicker.com/list/bjGvNN
Id like to know if his current psu wil do fine in this build. That being an old cooler master 430w power supply
Link: https://m.newegg.com/Product/index?itemnumber=N82E16817171007
are you sure it's the exact same model?
how old is it exactly?
also looking at the build, I'd go with something like that:
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor ($75.00 @ B&H)
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard ($71.98 @ Newegg)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory ($50.99 @ Newegg)
Video Card: Sapphire Radeon RX 460 4GB NITRO Video Card ($110.99 @ SuperBiiz)
Total: $308.96
Generated by PCPartPicker 2017-01-31 18:31 EST-0500
if you know a store that can update you the bios of the mainboard, you can go for an H110 board (=cheaper) and get a slightly better video card for the difference (1050 TI for example)
I actually found an open box 1050 ti 4gb that doesn't have a 6 pin. the build has to be 300 exact
